ESkul1
6 years agoAVSPI Core Attributes Failure
In one of the AVSPI core files, spiphyslave.v, are several set_false_path attributes that are causing several warnings such as the following, during Compile: /*local reg for shift register*/ (* al...
ESkul1
6 years agoHello YY, can you please provide a recommended work-around to resolve the constraint failures reported during Compile, inside the AVSPI core file, spiphyslave.v ?
I need to submit the design to production team as we are moving into production with this FPGA. I do not want to deliver product with possible timing defect.
Please try to understand I have a real deadline and need guidance on how to resolve this issue.
Thank you again for your time and help.
