ESkul1
6 years agoAVSPI Core Attributes Failure
In one of the AVSPI core files, spiphyslave.v, are several set_false_path attributes that are causing several warnings such as the following, during Compile: /*local reg for shift register*/ (* al...
ESkul1
6 years agoHello YY, can you provide any update info on this core constraint failure? My design can't be finalized until this core constraint issue is resolved. Thank you for your time and attention.
