ESkul1
6 years agoAVSPI Core Attributes Failure
In one of the AVSPI core files, spiphyslave.v, are several set_false_path attributes that are causing several warnings such as the following, during Compile: /*local reg for shift register*/ (* al...
KhaiChein_Y_Intel
6 years agoHi,
Can you provide the design for investigation? May I know which version of the software you are using?
