pdewanga's avatar
pdewanga
4 years ago
Avalon Streaming interface with PCIe as endpoint to AXI4 Converter
Hi Team,
Do we have any ip in platform generator that convert the Avalon Streaming Interface signals [ connected as as an pcie endpoint ] to the AXI4-ST interface signals.
We want to verify an media IP.
Please help and post any good article and implementation tips.
  • pdewanga's avatar
    pdewanga
    Or to reframe my question :
    Does Intel platform designer has any Hard IP which is equivalent to the Xilinx® UltraScale Devices Gen3 Integrated Block for PCIe® solution IP core ???
  • KennyT_altera's avatar
    KennyT_altera
    Thanks for using Intel community forum,
    Kindly expect some delay in the reply due to holiday.
  • Wincent_Altera's avatar
    Wincent_Altera
    We do have a Design comparison with Xilinx User, please refer the link below.
    What we would recommend based on the information that you provide at the moment will be Stratix and Agilex Family.
    Those common PCIe IP such as AVST, AVMM , DMA and others are available inside Quartus.
    For the other PCIe Design Example, you may refer to our FPGA Design Store.
    Let me know if any further clarification is needed.
    Wincent_Intel
    • pdewanga's avatar
      pdewanga
      Hi wchiah,
      You didn't answer the question well ,
      I want to use stratix10 fpga.
      Question is :
      Do we have any IP in platform generator that convert the Avalon Streaming Interface signals [ connected as as an pcie endpoint ] to the AXI4 Streaming interface signals ??
      Or same question reframed as below
      -Piyush
        Wincent_Altera
        Hi Piyush,
        Apologize for misunderstanding your question early on.
        1. Do we have any IP in platform generator that convert the Avalon Streaming Interface signals [ connected as a PCIe endpoint ] to the AXI4 Streaming interface signals ??
          We have a function call Bursting Adaption, but as I see it is only applicable to AVMM
          https://www.intel.com/content/www/us/en/docs/programmable/683609/21-3/burst-adaptation-to-axi.html
        2. Does Intel platform designer has any Hard IP which is equivalent to the Xilinx® UltraScale Devices Gen3 Integrated Block for PCIe® solution IP core
          Apologize that I not familiar with Xilinx product, but there is some comparison and recommended product with Xilinx UltraScale Device which is Intel Stratix 10 for example. Can I know which PCIe solution IP core you wish to compare with?
          Most of common PCIe Hard/Soft IP such as AVST, AVMM , DMA and others are available in Intel product as well.
        Let me know if the answer is still not clear.
        Wincent_C
    Wincent_Altera
    We do not receive any response from you to the previous answer that I have provided.
    This thread will be transitioned to community support.
    If you have a new question, feel free to open a new thread to get support from Intel experts.
    Otherwise, the community users will continue to help you on this thread. Thank you
    Wincent_C
    Wincent_Altera
    If you feel your support experience was less than a 9 or 10,
    please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
    Wincent_C
