Avalon Streaming interface with PCIe as endpoint to AXI4 Converter
We do have a Design comparison with Xilinx User, please refer the link below.
What we would recommend based on the information that you provide at the moment will be Stratix and Agilex Family.
Those common PCIe IP such as AVST, AVMM , DMA and others are available inside Quartus.
For the other PCIe Design Example, you may refer to our FPGA Design Store.
Let me know if any further clarification is needed.
Wincent_Intel
- pdewanga4 years ago
Hi wchiah,
You didn't answer the question well ,
I want to use stratix10 fpga.
Question is :
Do we have any IP in platform generator that convert the Avalon Streaming Interface signals [ connected as as an pcie endpoint ] to the AXI4 Streaming interface signals ??
Or same question reframed as below
Does Intel platform designer has any Hard IP which is equivalent to the Xilinx® UltraScale Devices Gen3 Integrated Block for PCIe® solution IP core ???
-Piyush
- Wincent_Altera4 years ago
Hi Piyush,
Apologize for misunderstanding your question early on.
- Do we have any IP in platform generator that convert the Avalon Streaming Interface signals [ connected as a PCIe endpoint ] to the AXI4 Streaming interface signals ??
We have a function call Bursting Adaption, but as I see it is only applicable to AVMM
https://www.intel.com/content/www/us/en/docs/programmable/683609/21-3/burst-adaptation-to-axi.html - Does Intel platform designer has any Hard IP which is equivalent to the Xilinx® UltraScale Devices Gen3 Integrated Block for PCIe® solution IP core
Apologize that I not familiar with Xilinx product, but there is some comparison and recommended product with Xilinx UltraScale Device which is Intel Stratix 10 for example. Can I know which PCIe solution IP core you wish to compare with?
Most of common PCIe Hard/Soft IP such as AVST, AVMM , DMA and others are available in Intel product as well.
Let me know if the answer is still not clear.
Wincent_C
Hi Wincent_C,
Thanks for responding .
Question for 1st comment,
Is the function call Bursting Adaption that you pointed out is present as "AXI Bridge Intel FPGA IP" under Bridges and Adaptors section in Platform Designer ? Just wanted to confirm attaching the below snap.
Question for 2nd comment,
Below is the xilinx PCIe core interface snap which has the AXI4 ST interface with requestor and completion both. I need this type of PCIe core in our Altera Stratix10 FPGA. If that is not present I am trying to use avmm pcie bridge as endpoint + AXI bridge Intel IP with this I can reach till axi4. But my requirement is AXI4-ST, for that I initiated the request with IPS but they are not helping us.
Thanks again for your help and hoping to get some more support from experts.
Piyush
