Avalon Streaming clock crosser does not generate HDL without errors. It cannot find it's own .v file
I want to generate an Avalon streaming clock crosser and when I clock on generate there is an error that says the altera file is not found. Is this a tool error that the file does not exist?
Error: st_clock_crosser_0: /nfs/site/disks/crt_tools_048/altera/quartus_prime_pro/22.1.0.174/ip/altera/avalon_st/altera_avalon_st_clock_crosser/altera_avalon_st_clock_crosser.v (No such file or directory)
- IntelSupport
Contributor
Yean in PD, try to generate the HDL and the issue came out as described?
Can we have a quick call?
- IntelSupport
Contributor
As per call, I can reproduce the issue, and indeed this is a tool bug.
Ill file to to developer for a fix and you may use AXI bridge as discussed.
- tejaswiniitagi
Actually I need clock converter from one frequency to another. The AXI bridge will not convert the clock. So I will need the clock crosser itself.
- IntelSupport
Contributor
This is legit bug during generation of hdl for this IP. I am reporting to to developer for fix.
- tejaswiniitagi
Can you please let me know when the fix will be done? I need to use the streaming clock crosser.
- IntelSupport
Contributor
Developer is working on that , the suggestion is to use use avalon streaming handshake clock crosser
- IntelSupport
Contributor
The developer mentioned that this IP will be discontinued and you may use the suggested IP and WA.
Let me know if there is any concern on this.
- IntelSupport
Contributor
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- tejaswiniitagi
/nfs/site/disks/crt_tools_048/altera/quartus_prime_pro/22.1.0.174/quartus/eda/sim_lib/altera_mf.v
This file has compilation errors when used to compile for handshake clock crosser.Can you please check if it compiles?
I'm getting the following error message
is not a hexadecimal value
