tejaswiniitagi
3 years agoAvalon Streaming clock crosser does not generate HDL without errors. It cannot find it's own .v file
I want to generate an Avalon streaming clock crosser and when I clock on generate there is an error that says the altera file is not found. Is this a tool error that the file does not exist?
Error...
IntelSupport
Contributor
3 years agoAs per call, I can reproduce the issue, and indeed this is a tool bug.
Ill file to to developer for a fix and you may use AXI bridge as discussed.
