11 years ago --- Quote Start --- I was trying to get to what Ted suggested above but not sure where I go to "export all ports" . --- Quote End --- "Export" is a column in the System Contents tab view of your system. For each interface of your component (clock, reset, Avalon-MM Master, Avalon-MM Slave, ...) just double click in that column. Qsys will put a default name in there for you, or you can type in your own name.
