11 years agoWhen I rum Modelsim, ld_debug command ...
I get this error . I guess it has something to do with the bridge ... I can try removing the bridge, re-generating synth, testbench and simulation environments andsee if the error goes away, but not having an indepth knowledge I will need to sepnd quite some time to track down the root cause. Thanks, Bob. Loading top_inst_pcie_av_hip_avmm_0_reconfig_clk_locked_bfm.altera_conduit_bfm # Loading top_inst_pio_0_leds_bfm.altera_conduit_bfm_0002 # ** Error: (vsim-3033) ./..//top_tb/simulation/top_tb.v(161): Instantiation of 'altera_avalon_mm_slave_bfm' failed. The design unit was not found. #
