MKlee2
6 years agoAvalon-MM Master Translator / Slave Translator gone in Quartus Prime Pro 19.4? (At least not visible)
I viewed an example design for ethernet/transceiver... in Quartus and noticed you handled the csr avalon-mm signal in a nice way using said ip (translator). I wanted to do something simmilar in my pr...
KennyT_altera
6 years agoHere is some feedback from the engineering:
Translator is meant to be used inside the interconnect with transform. Its parameterization depends on overall system configuration and can be correctly done by the transform. Hence the transform was removed from IP catalog. It still gets generated as part of interconnect.
