Automatic address range assignment ?
Hello Altera Experts,
I have a question about IP address range assignments when using Platform Designer. When i add IP to my Platform is there a way to get the tool to automatically assign non-overlapping address ranges to each IP ? At the moment when i add different IPs to my Platform they all overlap and so i have to go in to the address tab and manually assign each IP address range to make sure they don't overlap and thus causes errors.
Thanks for your help,
Barry
Yes. System menu -> Assign Base Addresses
- sstrell
- drbarryh
Contributor
Hi sstrell, right thanks for the help. I will use that method from now on.
best regards,
Barry
- KennyT_altera
Do you have further question?
- drbarryh
Contributor
Hi Kenny, thanks for the enquiry and no i think sstrell answered my question, unless there is something else you would like to add ?
best regards,,
Barry
- KennyT_altera
Not really, assigned base address is the way to go.
