18 years ago
asynchronous-parallel loadable shift register
Hi..
I want to know more about "asynchronous-parallel loadable shift register"..
The sentence is like..
the serial interface consists of an asynchronous-parallel loadable shift register.
As far as i know, Shift register is clear for me (It will shift data on each clock)
Parallel loadable mean a Function that allows loading of a binary value into counter.
Asynchronous mean not synchronous data with clock.
in short, Code is made of Shift register and Counter..
Am i correct or wrong ?? if wrong then please clear my defination.
Sorry for this question coz this is very very basic question.
Thanking you.
1 Reply
    The parallel load doesn't refer to a counter, but to the shift register itself. It just means you can load a parallel value into the register chain, and this will be shifted out on subsequent clocks. So it's a parallel to serial interface. The word 'asynchronous' in your case must mean that the parallel data is loaded straight onto the registers without a clock.
