16 years ago
Association internal signal - internal pin?
Can i associate an input of my entity that it is not a top level entity of my project to an internal pin of my board?
In particular i must use the sram of my cyclone ii , i want to create an entity sram in which i have an input chip enable, i want that this signal is the real chip enable of the sram.
Can i do it with the association of this input to the pin of my board?
And, how can i do it?
I seem that it is possible only for the top level entity.
1 Reply
    Yes it's only possible from the top level entity. If you want that signal to reach another entity, you'll have to connect it through the hierarchy. Declare it as a port in your entity, and in the instantiotion in the top level file, connect it to the pin.
