14 years agoassigning pins location to a component pin
Hi
this is a little complicated but I'll try to be clear: in order to get a clearer VHDL code, I want to reduce the number of ports in the top level entity. so I wanted to assign pins location to pins directly in the components, instead of connecting them to ports in the top level entity. so in the .qsf file I have something like: set_location_assignment PIN_A1 -to "my_srffe:b2v_inst1|Q" when I look in the floor plan I can see that the pin is assigned to the IO. but in the compilation report I get a warning that the assignment have been ignored because the node does not exist in the design. when I program the device it seems that the pin is not assigned. I tried using the keep attribute in the component architecture, but it didn't help. any ideas?
