10 years agoassigned a pin to ground
Hi everyone, I have a max10 FPGA and I want to assigned a pin to the gnd Because my circuit is like this: output pin(3.3V ) LED power supplied(3.3V) so If I wa...
10 years ago --- Quote Start --- The pins can source and drain the required current? I would reccommend using a ground pin. I think there must be a couple of those. --- Quote End --- Thank you for replying, I couldn't use a ground pin. Because I have to manage light up or light down the LED. Could I just connect the ground directly to an output in schematic, does it work?
