10 years agoassigned a pin to ground
Hi everyone, I have a max10 FPGA and I want to assigned a pin to the gnd Because my circuit is like this: output pin(3.3V ) LED power supplied(3.3V) so If I wa...
10 years ago --- Quote Start --- What is the value of your current limiting resistor? Did you put a scope or a meter to measure the output pin? Kevin Jennings --- Quote End --- Thank you for your replying, I couldn't really measure the current, now. Because I work in a starting project. But it was an experimented engineer, who develop that board. So I think he should think about that. I thought it may be have problem of compatibility of USB blaster II, which is not compatible with Altera max10 or the frequency of Jtag, 6MHz instead of 24MHz, but I don't know how to change that frequency
