10 years agoassigned a pin to ground
Hi everyone, I have a max10 FPGA and I want to assigned a pin to the gnd Because my circuit is like this: output pin(3.3V ) LED power supplied(3.3V) so If I wa...
10 years ago --- Quote Start --- Because my circuit is like this: output pin(3.3V ) LED power supplied(3.3V) so If I want to light up my LED, I should have an output pin=0V. I've try some VHDL code, it seems it doesn't work --- Quote End --- What is the value of your current limiting resistor? Did you put a scope or a meter to measure the output pin? Kevin Jennings
