graememe
7 months agoArria10 Platform Designer EMIF
Hi I am using platform designer with the Arria10. I have two DDR3 memory interfaces which use clock sharing so they should share the same clock domain. Platform designer inserts clock crossing logic...
sstrell
7 months agoCan you show your PD system design? You should be connecting directly between the EMIF IP components.
