Arria 10 GX Transceiver PHY will not configure to 64B/66B modes in Enhanced PCS mode
Hi Nathan( 2 separate errors, one for TX, one for RX enables)
Error: GRT_28G.xcvr_native_s10_htile_0: The current value "enabled" (1) for parameter "Enable RX 64b/66b decoder" (enh_rx_64b66b_enable) is invalid. Possible valid values are: "disabled" (0). The parameter value is invalid under these current parameter settings: "TX channel bonding mode" (bonded_mode)="Not bonded" (not_bonded) && "Number of data channels" (channels)="1" && "device" (device)="" (1SG280HN1F43E2VGS1) && "device_die_revisions" (device_die_revisions)="HSSI_CRETE2P_REVA MAIN_ND5_REVA" && "device_die_types" (device_die_types)="HSSI_CRETE2P MAIN_ND5" && "Enable manual PCS bonding settings" (enable_manual_bonding_settings)="disabled" (0) && "PMA configuration rules" (pma_mode)="basic" && "Transceiver configuration rules" (protocol_mode)="Basic (Enhanced PCS)" (basic_enh). Rule(s): hssi_10g_rx_pcs_dec_64b66b_rxsm_bypass.
Error: GRT_28G.xcvr_native_s10_htile_0: The current value "enabled" (1) for parameter "Enable TX 64b/66b encoder" (enh_tx_64b66b_enable) is invalid. Possible valid values are: "disabled" (0). The parameter value is invalid under these current parameter settings: "TX channel bonding mode" (bonded_mode)="Not bonded" (not_bonded) && "Number of data channels" (channels)="1" && "device" (device)="" (1SG280HN1F43E2VGS1) && "device_die_revisions" (device_die_revisions)="HSSI_CRETE2P_REVA MAIN_ND5_REVA" && "device_die_types" (device_die_types)="HSSI_CRETE2P MAIN_ND5" && "Enable manual PCS bonding settings" (enable_manual_bonding_settings)="disabled" (0) && "PMA configuration rules" (pma_mode)="basic" && "Transceiver configuration rules" (protocol_mode)="Basic (Enhanced PCS)" (basic_enh). Rule(s): hssi_10g_tx_pcs_enc_64b66b_txsm_bypass.
