10 years agoarrays in vhdl
how to do following operation in vhdl ? data <= walls_rand[{randh[1:0],address[3:0]}]; * here walls_rand is an array and data,randh,address are std_logic vectors *reg [5:0]walls_rand[0:6...
10 years ago --- Quote Start --- the code you have posted is verilog and you dont show how randh and address are declared in verilog. data <= walls_rand( to_integer( unsigned(randh(1 downto 0) & address(3 downto 0) ) ); --- Quote End --- whole verilog code as follow module wall_generator( input clk, input [63:0]rand, input hold, input [5:0]address, output reg [5:0]data ); reg [63:0]randh; reg [5:0]walls_rand[0:63]; reg [5:0]walls_alt[0:63]; reg [5:0]walls_maze[0:127]; always @(posedge clk) begin if(!hold) begin randh <= rand; end end always @* begin case(address[5:4]) 2'd0: begin data <= walls_rand[{randh[1:0],address[3:0]}]; end 2'd1: begin data <= walls_alt[{randh[3:2],address[3:0]}]; end 2'd2: begin data <= walls_rand[{randh[5:4],address[3:0]}]; end 2'd3: begin data <= walls_maze[{randh[8:6],address[3:0]}]; end endcase end
