13 years ago----------------------------------------------------------------------------------
-- Company: -- Engineer: -- -- Create Date: 18:44:30 11/26/2012 -- Design Name: -- Module Name: average - rem_trend -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.STD_LOGIC_ARITH.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity average is port ( b : in std_logic_vector(31 downto 0); data_out : out std_logic_vector(31 downto 0)); end average; architecture rem_trend of average is begin process(b) variable a1 : integer; variable c1 : real; begin for i in 1 to 31 loop b(i) := b(i-1) + b(i); end loop; a1 := b(31); c1 := a1/32; for i in 0 to 31 loop b(i) := b(i)-(3*c1); if (b(i) > 0) then b(i) := 0; end if; end loop; for i in 0 to 31 loop data_out(i)<=b(i); end loop; end process; end rem_trend; I tried this code.. removed package and put std_logic_vector..it gives me 2 errors HDL parsers 800 and HDL parsers 808
