13 years agoI tried this code
---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 18:44:30 11/26/2012 -- Design Name: -- Module Name: average - rem_trend -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use ieee.numeric_std.all; package but is type mat_arr is array(0 to 31) of real; end but; use work.but.all; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity average is port ( data : in mat_arr; data1 : in mat_arr; data_out : out mat_arr); end average; architecture rem_trend of average is signal my_int : mat_arr; begin process(data,data1,my_int) variable a1 : real; variable b : real; begin for i in 0 to 31 loop my_int(i)<=data(i); end loop; a1:=0.0; for i in 0 to 31 loop line 59 a1:=a1+my_int(i); end loop; b := a1/32.0; for i in 0 to 31 loop my_int(i) <= my_int(i)-(3.0*b); if (my_int(i) > 0.0) then my_int(i) <= 0.0; end if; end loop; for i in 0 to 31 loop data_out(i)<=my_int(i); end loop; end process; end rem_trend; but it shows error at line 59... real operand is not supported in this context!!!! please help...tomorrow is the last day for submission
