13 years agoI tried this code after going through that book....
---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 18:44:30 11/26/2012 -- Design Name: -- Module Name: average - rem_trend -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.STD_LOGIC_ARITH.ALL; package but is type mat_arr is array(0 to 31) of std_logic; type rem_tre is array(0 to 31) of std_logic; end but; use work.but.all; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity average is port ( data : in mat_arr; a : in integer; data_out : out rem_tre); end average; architecture rem_trend of average is begin process(data, a) begin for i in 1 to 31 loop line-50 data(i) <= data(i-1) + data(i); end loop; end process; end rem_trend; But while running in Xilinx ISE 14 I get the following error: ERROR:HDLParsers:808 - "C:/Users/vicky/array/average.vhd" Line 50. + can not have such operands in this context. I require a quick reply. Meanwhile I'll be trying... I would be very thankful for any help
