13 years ago --- Quote Start --- I don't know why this doesn't work and what exactly I need to add? --- Quote End --- Missing are - definition of signals and variables - declaration of port signals connecting in- and outputs Necessary corrections (at least) - correct VHDL assignment syntax - correct VHDL array index syntax - use a legal VHDL attribute instad of length[xxx] - use synthesizable types instead of real As you apparently missed your VHDL lectures, you should consider a good text book.
