TuckerZ's avatar
TuckerZ
3 years ago
Are Unpacked Array Supported in Platform Designer's Component Editor?
Hello, I'm trying to design an Avalon MM Slave and turn it into a component for use inside of platform designer using the component editor. In my top level HDL file, I have these two ports which ...
  • RichardT_altera's avatar
    3 years ago
    May I know which version of Quartus are you using, Standard or Pro?
    I'm afraid that if you are using Quartus Standard, there is limited support for the System Verilog language.
    Link: https://www.intel.com/content/www/us/en/docs/programmable/683283/18-1/verilog-and-systemverilog-synthesis-support.html
    The recommendations are as follows:
    1. Upgrade to Quartus Pro.
    2. Modify the design code by converting the multidimensional arrays into single-dimensional arrays.
    Unfortunately, the engineering team has no plans to enhance Quartus Standard.
    We apologize for any inconvenience caused by the limitations of the tool.
    Richard Tan
    Edited: Platform Designer does not support 2D arrays.
