12 years ago
"ARCTAN" Function's Issue
Hi bros, this is my VHDL code to implement an "ARCTAN" function:
-- This is my code --
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.MATH_REAL.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.numeric_std.ALL;
USE ieee.std_logic_signed;
USE ieee.std_logic_unsigned;
ENTITY arctan IS
GENERIC (NUMBER_BIT: INTEGER:=16);
PORT
clk: IN STD_LOGIC;
reset: IN STD_LOGIC;
data_inI: IN STD_LOGIC_VECTOR(NUMBER_BIT-1 DOWNTO 0);
data_inQ: IN STD_LOGIC_VECTOR(NUMBER_BIT-1 DOWNTO 0);
arc_out: OUT STD_LOGIC_VECTOR (5 DOWNTO 0)
END arctan;
ARCHITECTURE bhv OF arctan IS
BEGIN
PROCESS(clk,reset)
VARIABLE real_val1: REAL :=0.0;
VARIABLE real_val2: REAL :=0.0;
VARIABLE temp : REAL := 0.0;
BEGIN
IF (reset='0') THEN
arc_out<=(OTHERS=>'0');
ELSE IF(clk'EVENT AND clk='1') THEN
---convert STD_LOGIC type to REAL type----------
real_val1:= CONV_INTEGER(SIGNED(data_inI))**0.00003052; --1/(2^15)=1/32768=0.00003052
real_val2:= CONV_INTEGER(SIGNED(data_inQ))**0.00003052;
temp:=ARCTAN(real_val1,real_val2);
arc_out<= CONV_STD_LOGIC_VECTOR(CONV_SIGNED(INTEGER(temp*32768.0),6));
END IF;
END IF;
END PROCESS;
END bhv;
-- End of my code --
And when I tried to compile it with Modelsim-Altera Starter Edition 10.0, I got a message as shown below:
Can you help me to solve this issue? Thank you so much.
1 Reply
    You are including too many libraries. Those two are in direct conflict:
    The first one says you will want to do arithmetic directly on std_logic_vectors, using them as signed values, while the other one says you will use them as unsigned values. But both are non standard, so you should better remove them entirely.
    Then, as the error message suggests, both those libraries
    define a SIGNED type, so you should keep only one of them. I recommend to keep ieee.numeric_std.all, which is the only standard one.
    So as a result, use only those libraries in your code:
    And then fix the remaining errors that you get, mostly with the CONV functions that aren't defined any more. You can use the SIGNED type instead, and use the to_integer and to_signed functions for conversions.
    Are you writing this just for simulating, or also to synthesize and put in an FPGA? The functions from MATH_REAL and the real types can't be synthesized.
