aocl list-devices : No devices attached for package:
When i run "aocl list-devices" command what i get is following output
-bash-4.2$ aocl list-devices -------------------------------------------------------------------- Warning: No devices attached for package: <.....>/hld/board/a10_ref -------------------------------------------------------------------- Seems the device is not added properly. What could be the reason. Due to this I am not able to program my PAC.5 Replies
- HRZ
Please post the environmental variables you have set that are related to the Intel tools. There is likely something wrong with the way you have set the "ALTERAOCLSDKROOT" variable.
- JamesR
I am having the same problem - and I can provide more details. Perhaps answering my issue will help us both... I have the exact same issue: OpenCL doesn't know about my PAC card.
PLEASE help educate us about how to debug/solve this...
(I have ENVIRONMENT variables in NEXT post)...
My QUESTION: How do I debug (and solve) a “ERROR: CL_DEVICE_NOT_FOUND” for a system with a PAC card installed?
I think my issue is this: OpenCL can’t find the PAC card.
Here is an example of trying to use it:
% ~/inference_engine_samples/intel64/Release/security_barrier_camera_sample -d CPU -d_va FPGA -d_lpr CPU -i /opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/demo/../demo/car_1.bmp -m /opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/demo/../intel_models/vehicle-license-plate-detection-barrier-0106/FP32/vehicle-license-plate-detection-barrier-0106.xml -m_va /opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/demo/../intel_models/vehicle-attributes-recognition-barrier-0039/FP32/vehicle-attributes-recognition-barrier-0039.xml -m_lpr /opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/demo/../intel_models/license-plate-recognition-barrier-0001/FP32/license-plate-recognition-barrier-0001.xml
InferenceEngine:
API version ............ 1.2
Build .................. 13911
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin CPU
Build .................. lnx_20180510
Description ....... MKLDNNPlugin
[ INFO ] Loading plugin FPGA
Build .................. dliaPlugin
Description ....... dliaPlugin
[ INFO ] Loading network files for VehicleDetection
[ INFO ] Batch size is forced to 1
[ INFO ] Checking Vehicle Detection inputs
[ INFO ] Checking Vehicle Detection outputs
[ INFO ] Loading Vehicle Detection model to the CPU plugin
[ INFO ] Loading network files for VehicleAttribs
[ INFO ] Batch size is forced to 1 for Vehicle Attribs
[ INFO ] Checking VehicleAttribs inputs
[ INFO ] Checking Vehicle Attribs outputs
[ INFO ] Loading Vehicle Attribs model to the FPGA plugin
Location: /home/user/teamcity/work/scoring_engine_build/releases_openvino-2018-r3/thirdparty/dla/api/src/AOCL_Utils.cpp:398
Query for number of devices failed
Here is evidence that the card is plugged in (with BOARD info and everything!)…
% bwconfig --list
There are no mapped devices in your system.
% bwconfig --scan=usb
Scanning for devices
[result]: Board Type (Name), Serial, VendorID, DeviceID, USB-Address
[0]: 0x5f (A10SA4) 202101 0x2528 0x0004 0x6
% bwconfig --add=usb --result=0
Device added as device "0".
% bwconfig --list
Name Number ID Location Status
A10SA4 0 202101 Local USB Device Installed (New)
I did this after trying the run, and then tried the run again… NO change, OpenCL still doesn’t see the card… see this:
% aocl diagnose
Warning:
/home/james/inteldevstack/intelFPGA_pro/hld/board/a10_ref
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
I’m wondering - is “a10_ref” appropriate for a PAC (Arria 10)? I have NO other board reference files to point to - but the name does concern me. If there are OpenCL files for the PAC card to try… I’m eager to know that.
% aocl diagnose all
(no output)
% aocl diagnose 202101
202101 is not a valid device name.
% aocl diagnose 0
0 is not a valid device name.
% aocl diagnose 1
% aocl diagnose dev0
dev0 is not a valid device name.
% aocl diagnose dev1
dev1 is not a valid device name.
- JamesR
The is a FOLLOW-ON to my notes in the prior post - with environment variables for my version of the issue...
My environment variables…
% env
XDG_SESSION_ID=1009
HOSTNAME=psg_pool01
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
SELINUX_ROLE_REQUESTED=
TERM=xterm-256color
SHELL=/bin/bash
ALTERAOCLSDKROOT=/home/james/inteldevstack/intelFPGA_pro/hld
HISTSIZE=1000
SSH_CLIENT=192.168.1.29 59894 22
PERL5LIB=/home/james/perl5/lib/perl5:
SELINUX_USE_CURRENT_RANGE=
LIBVA_DRIVER_NAME=iHD
QSYS_ROOTDIR=/home/james/inteldevstack/intelFPGA_pro/qsys/bin
QTDIR=/usr/lib64/qt-3.3
QTINC=/usr/lib64/qt-3.3/include
PERL_MB_OPT=--install_base /home/james/perl5
SSH_TTY=/dev/pts/0
QT_GRAPHICSSYSTEM_CHECKED=1
USER=james
LD_LIBRARY_PATH=/home/james/inteldevstack/intelFPGA_pro/hld/host/linux64/lib:/home/james/inteldevstack/intelFPGA_pro/hld/board/a10_ref/linux64/lib:/home/james/inteldevstack/intelFPGA_pro/hld/board/a10_ref/linux64/lib:/home/james/inteldevstack/intelFPGA_pro/hld/host/linux64/lib:/opt/intel/computer_vision_sdk_fpga_2018.3.343/opencv/share/OpenCV/3rdparty/lib:/opt/intel/computer_vision_sdk_fpga_2018.3.343/opencv/lib:/opt/intel/opencl:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/inference_engine/external/cldnn/lib:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/inference_engine/external/gna/lib:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/inference_engine/lib/centos_7.3/intel64:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/model_optimizer/model_optimizer_caffe/bin:/opt/intel/computer_vision_sdk_fpga_2018.3.343/openvx/lib:
LS_COLORS=rs=0:di=38;5;27:ln=38;5;51:mh=44;38;5;15:pi=40;38;5;11:so=38;5;13:do=38;5;5:bd=48;5;232;38;5;11:cd=48;5;232;38;5;3:or=48;5;232;38;5;9:mi=05;48;5;232;38;5;15:su=48;5;196;38;5;15:sg=48;5;11;38;5;16:ca=48;5;196;38;5;226:tw=48;5;10;38;5;16:ow=48;5;10;38;5;21:st=48;5;21;38;5;15:ex=38;5;34:*.tar=38;5;9:*.tgz=38;5;9:*.arc=38;5;9:*.arj=38;5;9:*.taz=38;5;9:*.lha=38;5;9:*.lz4=38;5;9:*.lzh=38;5;9:*.lzma=38;5;9:*.tlz=38;5;9:*.txz=38;5;9:*.tzo=38;5;9:*.t7z=38;5;9:*.zip=38;5;9:*.z=38;5;9:*.Z=38;5;9:*.dz=38;5;9:*.gz=38;5;9:*.lrz=38;5;9:*.lz=38;5;9:*.lzo=38;5;9:*.xz=38;5;9:*.bz2=38;5;9:*.bz=38;5;9:*.tbz=38;5;9:*.tbz2=38;5;9:*.tz=38;5;9:*.deb=38;5;9:*.rpm=38;5;9:*.jar=38;5;9:*.war=38;5;9:*.ear=38;5;9:*.sar=38;5;9:*.rar=38;5;9:*.alz=38;5;9:*.ace=38;5;9:*.zoo=38;5;9:*.cpio=38;5;9:*.7z=38;5;9:*.rz=38;5;9:*.cab=38;5;9:*.jpg=38;5;13:*.jpeg=38;5;13:*.gif=38;5;13:*.bmp=38;5;13:*.pbm=38;5;13:*.pgm=38;5;13:*.ppm=38;5;13:*.tga=38;5;13:*.xbm=38;5;13:*.xpm=38;5;13:*.tif=38;5;13:*.tiff=38;5;13:*.png=38;5;13:*.svg=38;5;13:*.svgz=38;5;13:*.mng=38;5;13:*.pcx=38;5;13:*.mov=38;5;13:*.mpg=38;5;13:*.mpeg=38;5;13:*.m2v=38;5;13:*.mkv=38;5;13:*.webm=38;5;13:*.ogm=38;5;13:*.mp4=38;5;13:*.m4v=38;5;13:*.mp4v=38;5;13:*.vob=38;5;13:*.qt=38;5;13:*.nuv=38;5;13:*.wmv=38;5;13:*.asf=38;5;13:*.rm=38;5;13:*.rmvb=38;5;13:*.flc=38;5;13:*.avi=38;5;13:*.fli=38;5;13:*.flv=38;5;13:*.gl=38;5;13:*.dl=38;5;13:*.xcf=38;5;13:*.xwd=38;5;13:*.yuv=38;5;13:*.cgm=38;5;13:*.emf=38;5;13:*.axv=38;5;13:*.anx=38;5;13:*.ogv=38;5;13:*.ogx=38;5;13:*.aac=38;5;45:*.au=38;5;45:*.flac=38;5;45:*.mid=38;5;45:*.midi=38;5;45:*.mka=38;5;45:*.mp3=38;5;45:*.mpc=38;5;45:*.ogg=38;5;45:*.ra=38;5;45:*.wav=38;5;45:*.axa=38;5;45:*.oga=38;5;45:*.spx=38;5;45:*.xspf=38;5;45:
INTELFPGAOCLSDKROOT=/home/james/inteldevstack/intelFPGA_pro/hld
CL_CONTEXT_COMPILER_MODE_ALTERA=3
ModelOptimizer_ROOT_DIR=/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/model_optimizer/model_optimizer_caffe
MAIL=/var/spool/mail/james
PATH=/home/james/inteldevstack/intelFPGA_pro/quartus/bin:/home/james/inteldevstack/intelFPGA_pro/hld/bin:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/model_optimizer:/usr/lib64/qt-3.3/bin:/home/james/perl5/bin:/opt/bwtk/dhdev/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/james/inteldevstack/a10_gx_pac_ias_1_1_pv/bin:/home/james/.local/bin:/home/james/bin
BWTK=/opt/bwtk/dhdev
PWD=/home/james
InferenceEngine_DIR=/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/inference_engine/share
LANG=en_US.UTF-8
QUARTUS_HOME=/home/james/inteldevstack/intelFPGA_pro/quartus
OPAE_PLATFORM_ROOT=/home/james/inteldevstack/a10_gx_pac_ias_1_1_pv
KDEDIRS=/usr
OpenCV_DIR=/opt/intel/computer_vision_sdk_fpga_2018.3.343/opencv/share/OpenCV
MFX_HOME=/opt/intel/mediasdk
CL_CONTEXT_COMPILER_MODE_INTELFPGA=3
QUARTUS_ROOTDIR_OVERRIDE=/home/james/inteldevstack/intelFPGA_pro/quartus
SELINUX_LEVEL_REQUESTED=
DCP_LOC=/home/demo_user/DCP/1.0_PRC/release_pkg
HISTCONTROL=ignoredups
SHLVL=1
HOME=/home/james
PERL_LOCAL_LIB_ROOT=:/home/james/perl5
PYTHONPATH=/opt/intel/computer_vision_sdk_fpga_2018.3.343/python/python3.6:/opt/intel/computer_vision_sdk_fpga_2018.3.343/python/python3.6/centos7:/opt/intel/computer_vision_sdk_fpga_2018.3.343/deployment_tools/model_optimizer:
LOGNAME=james
QTLIB=/usr/lib64/qt-3.3/lib
XDG_DATA_DIRS=/home/james/.local/share/flatpak/exports/share/:/var/lib/flatpak/exports/share/:/usr/local/share/:/usr/share/
SSH_CONNECTION=192.168.1.29 59894 192.168.1.13 22
LESSOPEN=||/usr/bin/lesspipe.sh %s
AOCL_BOARD_PACKAGE_ROOT=/home/james/inteldevstack/intelFPGA_pro/hld/board/a10_ref
XDG_RUNTIME_DIR=/run/user/1001
DISPLAY=localhost:10.0
QT_PLUGIN_PATH=/usr/lib64/kde4/plugins:/usr/lib/kde4/plugins
INTEL_CVSDK_DIR=/opt/intel/computer_vision_sdk_fpga_2018.3.343
PERL_MM_OPT=INSTALL_BASE=/home/james/perl5
_=/usr/bin/env
I would REALLY enjoy any feedback/hints/tips on how to debug (and solve) a “ERROR: CL_DEVICE_NOT_FOUND” for a system with a PAC card installed… THANK YOU!!!
- HRZ
@JRein, I don't think the PAC card is the same as the a10_ref board. The latter is a development board with one bank of DDR3 and one bank of DDR4 while the PAC card has two DDR4 banks. You most definitely need a BSP specific to the PAC card. Contact whoever you purchased the board from to get the respective BSP. Furthermore, it seems you have not even set up your board. You need to program the board via JTAG with a base firmware to enable the PCI-E core before it is detected using aocl diagnose. Intel's documents outline the steps to do so.
- JamesR
Thank you. Yes, it turns out "PAC A10" is different than "A10 REF" - and I needed "PAC A10." And, the firmware was flashed but with a version that was too old now for the current OpenCL. So, I needed to flash a newer firmware in the PAC card. Once I got the PAC A10 BSP, and flashed the newer firmware (that matches the BSP) - everything worked. A very helpful support engineer at Intel helped me find the right files and everything works now. The key was having the right combination of firmware on the card, OpenCL driver and BSP, and other libraries... and then it all just work. Very nicely indeed.
