8 years agoaocl list-devices : No devices attached for package:
When i run "aocl list-devices" command what i get is following output -bash-4.2$ aocl list-devices -------------------------------------------------------------------- Warning: No devices...
JamesR
8 years agoThank you. Yes, it turns out "PAC A10" is different than "A10 REF" - and I needed "PAC A10." And, the firmware was flashed but with a version that was too old now for the current OpenCL. So, I needed to flash a newer firmware in the PAC card. Once I got the PAC A10 BSP, and flashed the newer firmware (that matches the BSP) - everything worked. A very helpful support engineer at Intel helped me find the right files and everything works now. The key was having the right combination of firmware on the card, OpenCL driver and BSP, and other libraries... and then it all just work. Very nicely indeed.
