aocl-clang exists but is not working!
I try run hello_world and get this error:
C:\Windows\system32>aocl version aocl 16.0.0.211 (Altera SDK for OpenCL, Version 16.0.0 Build 211, Copyright (C) 2016 Altera Corporation) C:\Windows\system32>%ALTERAOCLSDKROOT%\init_opencl.bat AOCL_BOARD_PACKAGE_ROOT is set to C:\altera\16.0\hld\board\s5phq. Using that. Adding C:\altera\16.0\hld\bin to PATH Adding C:\altera\16.0\hld\host\windows64\bin to PATH Adding C:\altera\16.0\hld\board\s5phq\windows64\bin to PATH C:\Windows\system32>cd C:\Users\usuario\Documents\Master\hello_world C:\Users\usuario\Documents\Master\hello_world>aoc -march=emulator device\hello_w orld.cl -o bin\hello_world.aocx --board s5phq_a7 Error: aoc: Executable C:/altera/16.0/hld/windows64/bin/aocl-clang exists but is not working! The cause of failure cannot be determined. Run executable manually and watch for error messages. Can anybody help me?11 Replies
Since you seem to have installed Quartus in Drive C, assuming that you are using Windows 10 or you have UAC enabled, windows security settings could be interfering with the process. Starting a cmd session as admin and test with that to see if it bypasses the problem.
Hi HRZ,
I'm using Windows 7 and UAC disabled. I starting a cmd session as admin and test but the error continued. - Altera_Forum
Did you try running the "aocl-clang" executable manually and see what happens as suggested by the original error message?
Hi, i have the same issue but in Ubuntu environment. When i did execute "aocl-clang" manually the system reported:
error while loading shared libraries: libmip_common.so: cannot open shared object file: No such file or directory Now, i'm trying to solve this missed library - Altera_Forum
That library is shipped with Quartus itself. Either your installation is incomplete or you have not added the path to the libraries required by the OpenCL compiler to LD_LIBRARY_PATH.
- MDavi14
Hi, I have the some problems with aocl-clang. do you have any documentation? I have problems with -board argument
- SDesh12
Hey
I am facing a similar issue.
C:\intelFPGA_pro\Examples\1.hotspot>aoc -v -board=s10gx device/hotspot.cl -o bin/hotspot.aocx
aoc: Clang version:
Error: aoc: Executable C:/intelFPGA_pro/19.1/hld/windows64/bin/../../llvm/bin/aocl-clang exists but is not working!
Where you able to solve this?
- HRZ
Did you try the existing suggestions? Specifically, running the aocl-clang binary directly to see what error message it will print?
- lnlnln
I also encountered this problem, but it has been solved. Everyone may have a different reason for this problem. Let me talk about my situation.
I encountered this situation because the system environment variable PATH lacks the following path:
As for why the lack of these will lead to this problem, emmmm, maybe, I don't know, and if it causes this problem, you should also find that command shutdown will be invalid at the command prompt.
