8 years agoaocl-clang exists but is not working!
I try run hello_world and get this error: C:\Windows\system32>aocl version aocl 16.0.0.211 (Altera SDK for OpenCL, Version 16.0.0 Build 211, Copyright (C) 2016 Altera Corporation) C...
lnlnln
7 years agoI also encountered this problem, but it has been solved. Everyone may have a different reason for this problem. Let me talk about my situation.
I encountered this situation because the system environment variable PATH lacks the following path:
As for why the lack of these will lead to this problem, emmmm, maybe, I don't know, and if it causes this problem, you should also find that command shutdown will be invalid at the command prompt.
