10 years agoAocl based SD card creation
I was reading this, https://documentation.altera.com/#/00015360-AA$NT00067112
Where can i get the guide to create this SD card contents?3 Replies
Hi, you can get this image under the sdl installation folder in hld.. depend on which board you are using.
thanks,this is a complete boot able image, where can i get the steps to create this SD card, i mean the content such as rbf and the device tree and preloader?
never seen that doc before, as this is a total separated procedure from the GHRD that you can read from rocket boards. For normal aocl usage, user don;t need to change other content, right?
