11 years agoAOC Compilation Fails
Hello everyone,
I am currently using AOCL 14.0 installed on CentOS 6.5 with de5-net board. Sometimes about 2 minutes into the compilation I would receive the following error: ... 2015.01.24.02:14:20 error: s0: cannot find sequencer/sequencer.elf 2015.01.24.02:14:20 error: s0: an error occurred 2015.01.24.02:14:20 error: generation stopped, 257 or more modules remaining error: ip-generate failed. refer to lu_blocked/lu_blocked.log for details. And in the log file this is the error (It's a little bit long, so I reduced the font size): 2015.01.23.21:37:12 info: p0: generating clock pair generator 2015.01.23.21:37:18 info: p0: generating system_acl_iface_ddr3a_p0_altdqdqs 2015.01.23.21:37:26 info: p0: 2015.01.23.21:37:26 info: p0: ***************************** 2015.01.23.21:37:26 info: p0: 2015.01.23.21:37:26 info: p0: remember to run the system_acl_iface_ddr3a_p0_pin_assignments.tcl 2015.01.23.21:37:26 info: p0: script after running synthesis and before fitting. 2015.01.23.21:37:26 info: p0: 2015.01.23.21:37:26 info: p0: ***************************** 2015.01.23.21:37:26 info: p0: 2015.01.23.21:37:26 info: p0: "ddr3a" instantiated altera_mem_if_ddr3_phy_core "p0" 2015.01.23.21:37:26 info: m0: "ddr3a" instantiated altera_mem_if_ddr3_afi_mux "m0" error: cannot find sequencer/sequencer.elf 2015.01.23.21:37:29 error: s0: cannot find sequencer/sequencer.elf 2015.01.23.21:37:29 error: s0: an error occurred while executing "error "an error occurred"" (procedure "_error" line 8) invoked from within "_error "cannot find $seq_file"" ("if" then script line 2) invoked from within "if {[file exists $seq_file] == 0} { _error "cannot find $seq_file" }" (procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14) invoked from within "alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"" invoked from within "set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"]]" ("if" then script line 2) invoked from within "if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} { set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequenc..." (procedure "generate_qsys_sequencer_sw" line 872) invoked from within "generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name $ac_rom_init_file_name ..." invoked from within "set seq_mem_size_list [generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name ..." ("if" else script line 2) invoked from within "if {[::alt_mem_if::util::qini::qini_value alt_mem_if_seq_size_request 0] > 0} { set seq_mem_size [::alt_mem_if::util::qini::qini_value alt_mem_if_se..." (procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer" line 207) invoked from within "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}" invoked from within "set qsys_sequencer_files_list [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}]" (procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3) invoked from within "alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "ddr3" $tmpdir quartus_synth" invoked from within "foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "ddr3" $tmpdir quartus_synth] { set file_name [file tail $genera..." (procedure "generate_synth" line 8) invoked from within "generate_synth system_acl_iface_ddr3a_s0" 2015.01.23.21:37:29 info: s0: "ddr3a" instantiated altera_mem_if_ddr3_qseq "s0" 2015.01.23.21:37:29 error: generation stopped, 257 or more modules remaining 2015.01.23.21:37:29 info: system: done "system" with 126 modules, 226 files After this error is encountered, I can't even compile vector_add example anymore. Sometimes logout and log back in could fix the issue, but other times only rebooting the computer can fix this. Also, this only occurs in Linux, I have never seen this under Windows. Does anybody know what might have caused this, and if there is any fix to it?
