16 years agoAnalysis & Synthesis was canceled due to an error
After running synthesis for about a minute, I saw this pop-out message, "Analysis & Synthesis was canceled due to an error (68 warnings)", which stopped my synthesis. However, when I checked the error/warning/message window below, it did not specify an error, i.e. the error message window is empty. The last info message is:
"Info: Found 1 design units, including 1 entities, in source file ../src_rtl/ehi/gmac/gmac_ip/mmc/DWC_gmac_mmc.v Info: Found entity 1: DWC_gmac_mm". Anyone knows or has good suggestion as to why my synthesis could not proceed?
