16 years ago --- Quote Start --- Just wonder if there is an obvious reason why synthesis stopped without showing an error --- Quote End --- Most likely not obvious. The issue may be trigerred by a design error or a design detail unexpected by the compiler. You can try to identify it by rolling back the design changes. And if you found the step, that introduced the error, to dissect it further.
