14 years ago
An Internal Error while using quartus II 9.0 ,waiting for help
Internal Error: Sub-system:AMERGE,File:/quartus/atm/amerge/amerge_kpt_op.cpp,Line:390
kpt_mgr->save_keypoints_db(map_kpt_db->get_name(),map_save_file_name)
Stack Trace:
0x3E2AF: amerge_mini_merge+0x3AECF(atm_merge)
End-trace
Quartus II Version 9.0 Build 132 02/25/2009 SJ Full Version
I've met this problem, and don't know how to solve it. If you know why, will you give me the resolusion or some advice? Many thanks!
    1. you can try deleting db and incremental_db in the project directory
    2. if that doesn't work you should update to a newer Quartus II
    So many thanks PanCake! Deleting the db and incremental db worked for me!
    Rgds
    Balu
