SeanAB
1 year agoALTPLL will not get installed in Platform Builder
Quartus Prime Lite 24.1 on Windows 1. I am able to add ALTPLL as a component to blank project without issue. The wizard builds the files no problem. I was able to do the basic blink mux counter proj...
KennyT_altera
1 year agoThe previous KDB pointed is listed with a Fatal error, from your side, do you see any error message?
- SeanAB1 year ago
@KennyTan_Altera thank you for the response.
Replying to both responses:
1. I am using Quartus Prime Lite 24.1 for a MAX10 10M50 Evaluation Kit. Pro edition 25.1.1 is not possible.
2. There is no error message. It just closes without adding the ATPLL
After implementing the fix shared in an older Stack Exchange post, the wizard completes successfully.
