ALTPLL ouput clock doesn't synchronize.
Hi Minkyo
Thanks for your inquiry. May I know if your input reference clock is misaligned with PLL's output clock? Or do you mean you have multiple PLL's outclocks misaligned?
Eng Wei
Hi
Thank you for the answer.
I mean, the output clocks misaligned.
For example, when Plll outputs a,b,c, a,b,c are not aligned each other.
Could I make output clocks aligned ?
- EngWei_O_Intel6 years ago
Hi Minkyo
Sorry for late response. May I know which PLL or fPLL you are using? Are you able to get the exact output freq 12.288Mhz, 3.072Mhz, and 48KHz? If the exact freq isn't available, you the outclk might be misaligned.
Eng Wei
Hi Minkyo
Hope you are doing fine. We do not receive any response from you to the previous question that have been asked. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
