13 years agoaltmult_add megafunction
I am using the following:
1. quartus 11.1 sp2 2. modelsim altera starter edition 10.0c 3. arria v i have created an altmult_add using the megawizard, and the following was created: component fakir_1_altmult_add_coef PORT ( aclr0 : IN STD_LOGIC := '0'; clock0 : IN STD_LOGIC := '1'; coefsel0 : IN STD_LOGIC_VECTOR (2 DOWNTO 0); dataa_0 : IN STD_LOGIC_VECTOR (11 DOWNTO 0) := (OTHERS => '0'); datab_0 : IN STD_LOGIC_VECTOR (11 DOWNTO 0) := (OTHERS => '0'); ena0 : IN STD_LOGIC := '1'; result : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component; i am using this component in my design, but when i try simulating it i recieve the following warning in the modelsim: ** Warning: (vsim-3473) Component instance "altera_mult_add1 : altera_mult_add" is not bound.# Time: 0 ps Iteration: 0 Instance: /fakir_calc_tb/fakir_1_altmult_add_coef_1/fakir_1_altmult_add_coef_mult_add_3fh4_component File: C:/Repositories/HD3.0/RedTailedHawk/RTL/IWP/fakir/fakir_calc/fakir_1_altmult_add_coef.vhd and the simulation results in an 'U' output from this component, i can't find the reason for it. help is requiered. Thanks.
