Alterad fails to work with new license
Hi
Thanks for update. Could you restart server.
Solution:
Restart your Windows/Linux Server to eliminate all services and force a new start. On Windows, check the “Force Server Shutdown” box on the “Start/Stop/Reread” tab in lmtools.exe. Open the LMTOOLS again and perform status enquiry, it should show the SERVER UP now.
Start the service to see if it launches. You will see a small message at the bottom of the LMTools windows stating if it started or not.
If it does not start, select the 'Config Services' tab and select 'View Log'. Make a copy of this log and attach for further checking.
- NJackson3 years ago
I've attached a copy of the log when attempting to start using our new license file (the one that doesn't appear to work). Also I've added below the output from 'Perform Status Enquiry'.
Status
Flexible License Manager status on Fri 8/4/2023 14:02
[Detecting lmgrd processes...]
License server status: 27001@BPL-DEV01
License file(s) on BPL-DEV01: C:\flexlm\LR-127929_License.dat:
BPL-DEV01: license server UP (MASTER) v11.18.2
Vendor daemon status (on BPL-DEV01):
alterad: UP v11.18.2
Feature usage info:
Users of ip_base: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of ip_embedded: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of maxplus2verilog: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of maxplus2vhdl: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of quartus_nonvolatile_encryption: (Total of 8 licenses issued; Total of 0 licenses in use)
Users of sw_pe: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of maxplus2: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of quartus_pro: (Total of 8 licenses issued; Total of 0 licenses in use)
Users of quartus: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 6AF7_00A2: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 6AF7_00BE: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 6AF7_00BF: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 6AF7_00BD: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 6AF7_010C: (Total of 2 licenses issued; Total of 0 licenses in use)
Users of 6AF7_0034: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 6AF7_00D8: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of 6AF7_0014: (Total of 4 licenses issued; Total of 0 licenses in use)
mgcld: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: mgcvipae
Server name: 10.125.0.90
License path: 27001@BPL-DEV01;
FlexNet Licensing error:-15,578. System Error: 10049 "WinSock: Invalid address"
