12 years ago
Altera Quartus II Error
i am using the cyclone III Altera with Quartus II and my system specifications are 1 GB RAM, 500 GB Hard disk and Intel dual core processor, i am trying to implement Smwedly model of power converter, the error i am facing is
" error: quartus ii fitter was unsuccessful. 2 errors, 17 warnings
info: allocated 151 megabytes of memory during processing
error: processing ended: fri july 05 20:31:32 2013
error: elapsed time: 00:00:10
error: quartus ii full compilation was unsuccessful. 2 errors, 17 warnings" "
i am seeking guidelines about the error i am facing is that the RAM ?
please guide
Azhar
    Ia that the complete errpr message? Not really informative..
    I believe there are mire details of the error
    Only thing thats in your message here about memory is the info about how much memory is used, not that memory is the problem
    Thank you very much for help , i am actually beginner so it is quite confusing for me, i am pasting the Error again following in order to seek help
    Info: Found 2 design units, including 1 entities, in source file latchSR.vhd
    Info: Found design unit 1: latchSR-rtl
    Info: Found entity 1: latchSR
    Error (10430): VHDL Primary Unit Declaration error at modulatore30aprile.vhd(devil): primary unit "modulatore30aprile" already exists in library "work"
    Info (10499): VHDL information at azhar.vhd(devil): object "modulatore30aprile" is declared here
    Info: Found 0 design units, including 0 entities, in source file modulatore30aprile.vhd
    Info: Found 2 design units, including 1 entities, in source file modulatore30apriletest.vhd
    Info: Found design unit 1: modulatore30apriletest-architettura1
    Info: Found entity 1: modulatore30apriletest
    Error (10430): VHDL Primary Unit Declaration error at modulatore_finale.vhd(devil): primary unit "modulatore_finale" already exists in library "work"Info: Found 2 design units, including 1 entities, in source file sel_shift.vhd
    Info: Found design unit 1: sel_shift-scalamento
    Info: Found entity 1: sel_shift
    Info: Found 2 design units, including 0 entities, in source file sine_package.vhd
    Info: Found design unit 1: sine_package
    Info: Found design unit 2: sine_package-body
    Info: Found 2 design units, including 1 entities, in source file sine_wave.vhd
    Info: Found design unit 1: sine_wave-arch1
    Info: Found entity 1: sine_wave
    Info: Found 2 design units, including 1 entities, in source file sinewavecomplex.vhd
    Info: Found design unit 1: sinewavecomplex-arch11
    Info: Found entity 1: sinewavecomplex
    Info: Found 2 design units, including 1 entities, in source file Vhdl2.vhd
    Info: Found design unit 1: vhdl2-rtl
    Info: Found entity 1: vhdl2
    Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
    Info: Allocated 151 megabytes of memory during processing
    Error: Processing ended: Mon Jul 08 15:31:40 2013
    Error: Elapsed time: 00:00:02
    Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings
    can you please help?
    Thank you very much for help , actually i am beginner so it is quite confusing for me,
    here i am pasting the Errors again in order to seek help
    could you please help?
    I am not sure, but it might be that you have included some entities or files with the same names in your project.
    Quartus doesn't know which one it needs to use than.
    modulatore30aprile
    modulatore_finale
    Those are the ones declared twice if I understand the message correctly
