12 years ago
Altera preprocessor definitions
Hi all OpenCL / FPGA hackers
I'm working on some OpenCL that I would like to run on our Bittware FPGA card and compare against GPU version (an obvious exercise, which I am sure many have already done). Now while OpenCL is portable, this does not translate to performance portability, so to make a fare comparison I should optimise the OpenCL for an ALtera FPGA and then for th NVidia Card... there should be plenty of code resuse but there will be certain vendor specific things ( num_simd_work_items on the Device side, or changing the kernel coding style significantly in places) so I'd like to do something like
# ifdef __ALTERA__
// special optimised FPGA kernel code# else
// GPU optimised kernel code# endif
But I can find anything about such definitions being asserted by aoc
Does anyone have insider information about the defintions made by aoc?
If not then I can just manually assert -D__ALTERA__ and thats fine... but I'd like to know any proper defintions.
Thank you in advanced,
    I believe that ALTERA_CL is a preprocessor definition that aoc will automatically set for you upon compilation. Also, __attribute__(...) should be ignored by a vendor's OpenCL compiler if it is not understood, maybe generate a compile warning, but not a compile error.
    Are there any other preprocessor definitions that you have in mind?
    Cheers!
    --- Quote Start ---
    Cheers!
    --- Quote End ---
    No I think ALTERA_CL will be sufficient for my needs thankyou, I mainly what to have the FPGA and GPU optimised code in the same source file.
    Thank you
