11 years agoAltera PLL IP Core failed to launch in Quartus 14.1 on Ubuntu 15.04
Hello Guys
I am running Quartus 14.1 on Ubuntu 15.04. It is installed in /home/altera/14.1 path. But the problem is whenever I try to generate Altera PLL IP through IP Catalog, it fails after I press finish. I get the following error Info: Generating simgen model Error: Execution of script /tmp/alt6582_3281364987958848321.dir/0002_alterapll_gen/proj.tcl failed Error: Info: ******************************************************************* ... I would appreciate your help. You can link the solution if someone already has this question answered on this forum Thanks4 Replies
This seems to be something related to Quartus internal. Can you try with the latest Quartus II 15.0 to see if similar issue exist?
Do you have other OS to try? Perhaps Windows 7?
Have the same behaviour with Q15.0.2 on ubuntu 14.04. No problems on windows or CentOs.
Info: pll128l: Variation language : Verilog Info: Generating simgen model Error: Execution of script /tmp/alt6645_3290937605019557264.dir/0002_pll128l_gen/proj.tcl failed ... Error: Info: Command: quartus_sh -t /tmp/alt6645_3290937605019557264.dir/0002_pll128l_gen/proj.tcl Error: Info (23030): Evaluation of Tcl script /tmp/alt6645_3290937605019557264.dir/0002_pll128l_gen/proj.tcl was successful Error: Info: Quartus II 64-Bit Shell was successful. 0 errors, 0 warnings ... Error: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! Error: Execution of script run_simgen_cmd.tcl failed ... Error: Info: Command: quartus_sh -t run_simgen_cmd.tcl ... Error: Info: Command: quartus_map pll128l.qpf --simgen --ini=disable_check_quartus_compatibility_qsys_only=on --simgen_parameter=CBX_HDL_LANGUAGE=VERILOG ... Error: Info (281010): Generating sgate simulator netlist using Simgen Error: SIMGEN_PROGRESS Start of Model generation -- 0% complete Error: SIMGEN_PROGRESS Phase 1 : Internal Objects created -- 25% complete Error: SIMGEN_PROGRESS Phase 2 : Connections between internal objects made -- 60% complete Error: SIMGEN_PROGRESS Phase 3 : Netlist generated -- 100% complete Error: Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 0 warnings ... Error: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! Error: Info (23030): Evaluation of Tcl script run_simgen_cmd.tcl was successful Error: Info: Quartus II 64-Bit Shell was successful. 0 errors, 0 warnings Error: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! ... Info: Simgen was successful <html>Info: Done "<b>pll128l</b>" with 1 modules, 1 files Info: Generated simulation scripts for Modelsim in .../pll128l_sim/mentor directory. Info: Generated simulation scripts for VCS and VCS MX in .../pll128l_sim/synopsys directory. Info: Generated simulation scripts for NCSIM in .../pll128l_sim/cadence directory. Info: Generated simulation scripts for Riviera-PRO in .../pll128l_sim/aldec directory. The message "Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed!" sould been already solved with a patch in Q14 ... Any ideas? Thanks! - Altera_Forum
in quartus/linux64:
After "removing" some shared objects (thanks for the help from Altera), i got it running: sudo mv libccl_curl_drl.so libccl_curl_drl.so_backup sudo mv crashreporter crashreporter_backup sudo mv crashreporter.dep crashreporter.dep_backup sudo mv libcurl.so.4 libcurl.so.4.backup Got some new messages: quartus: /opt/altera/15.0/quartus/linux64/libssl.so.1.0.0: no version information available (required by /usr/lib/x86_64-linux-gnu/libcurl.so.4) quartus: /opt/altera/15.0/quartus/linux64/libssl.so.1.0.0: no version information available (required by /usr/lib/x86_64-linux-gnu/libcurl.so.4) quartus: /opt/altera/15.0/quartus/linux64/libcrypto.so.1.0.0: no version information available (required by /usr/lib/x86_64-linux-gnu/libcurl.so.4) These can be ignored or "fixed" by forcing quartus to use the ubuntu libs: sudo mv libssl.so.1.0.0 libssl.so.1.0.0.backup sudo mv libcrypto.so.1.0.0 libcrypto.so.1.0.0.backup Dirk
