11 years agoAltera PLL IP Core failed to launch in Quartus 14.1 on Ubuntu 15.04
Hello Guys I am running Quartus 14.1 on Ubuntu 15.04. It is installed in /home/altera/14.1 path. But the problem is whenever I try to generate Altera PLL IP through IP Catalog, it fails after I pr...
11 years agoHave the same behaviour with Q15.0.2 on ubuntu 14.04. No problems on windows or CentOs.
Info: pll128l: Variation language : Verilog Info: Generating simgen model Error: Execution of script /tmp/alt6645_3290937605019557264.dir/0002_pll128l_gen/proj.tcl failed ... Error: Info: Command: quartus_sh -t /tmp/alt6645_3290937605019557264.dir/0002_pll128l_gen/proj.tcl Error: Info (23030): Evaluation of Tcl script /tmp/alt6645_3290937605019557264.dir/0002_pll128l_gen/proj.tcl was successful Error: Info: Quartus II 64-Bit Shell was successful. 0 errors, 0 warnings ... Error: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! Error: Execution of script run_simgen_cmd.tcl failed ... Error: Info: Command: quartus_sh -t run_simgen_cmd.tcl ... Error: Info: Command: quartus_map pll128l.qpf --simgen --ini=disable_check_quartus_compatibility_qsys_only=on --simgen_parameter=CBX_HDL_LANGUAGE=VERILOG ... Error: Info (281010): Generating sgate simulator netlist using Simgen Error: SIMGEN_PROGRESS Start of Model generation -- 0% complete Error: SIMGEN_PROGRESS Phase 1 : Internal Objects created -- 25% complete Error: SIMGEN_PROGRESS Phase 2 : Connections between internal objects made -- 60% complete Error: SIMGEN_PROGRESS Phase 3 : Netlist generated -- 100% complete Error: Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 0 warnings ... Error: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! Error: Info (23030): Evaluation of Tcl script run_simgen_cmd.tcl was successful Error: Info: Quartus II 64-Bit Shell was successful. 0 errors, 0 warnings Error: Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! ... Info: Simgen was successful <html>Info: Done "<b>pll128l</b>" with 1 modules, 1 files Info: Generated simulation scripts for Modelsim in .../pll128l_sim/mentor directory. Info: Generated simulation scripts for VCS and VCS MX in .../pll128l_sim/synopsys directory. Info: Generated simulation scripts for NCSIM in .../pll128l_sim/cadence directory. Info: Generated simulation scripts for Riviera-PRO in .../pll128l_sim/aldec directory. The message "Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed!" sould been already solved with a patch in Q14 ... Any ideas? Thanks!
