11 years agoAltera PLL IP Core failed to launch in Quartus 14.1 on Ubuntu 15.04
Hello Guys I am running Quartus 14.1 on Ubuntu 15.04. It is installed in /home/altera/14.1 path. But the problem is whenever I try to generate Altera PLL IP through IP Catalog, it fails after I pr...
11 years agoin quartus/linux64:
After "removing" some shared objects (thanks for the help from Altera), i got it running: sudo mv libccl_curl_drl.so libccl_curl_drl.so_backup sudo mv crashreporter crashreporter_backup sudo mv crashreporter.dep crashreporter.dep_backup sudo mv libcurl.so.4 libcurl.so.4.backup Got some new messages: quartus: /opt/altera/15.0/quartus/linux64/libssl.so.1.0.0: no version information available (required by /usr/lib/x86_64-linux-gnu/libcurl.so.4) quartus: /opt/altera/15.0/quartus/linux64/libssl.so.1.0.0: no version information available (required by /usr/lib/x86_64-linux-gnu/libcurl.so.4) quartus: /opt/altera/15.0/quartus/linux64/libcrypto.so.1.0.0: no version information available (required by /usr/lib/x86_64-linux-gnu/libcurl.so.4) These can be ignored or "fixed" by forcing quartus to use the ubuntu libs: sudo mv libssl.so.1.0.0 libssl.so.1.0.0.backup sudo mv libcrypto.so.1.0.0 libcrypto.so.1.0.0.backup Dirk
