15 years agoIt was brought up on an earlier post in this thread that the user had a lot of AHDL and couldn't use it any more. The way AHDL/Schematics used to be simulated was by running quartus_map and then running the simulator. (There was a "Generate Functional Simulation", which just ran quartus_map, maybe with some options to make it quickly). To simulate, you would now do the same thing, but also run the EDA Netlist Writer to write out a simulation model, and then use that in modelsim. So it's definitely the same change as anyone else complaining about having to go to Modelsim, but it's not like AHDL/Schematic has been dropped.
