18 years agoIt is probably possible to use comments structures like intended_family or altera_internal to direct the synthesizer to ignore parts of the code depending on the selected target device, but this would probably result in very non-portable and hard to maintain code (assuming you would be able to get documentation about those from Altera).
You might as well write your code in AHDL which has everything you are asking for... Now, all the assignments (including the device family) are available in the TCL environment of the project. The elegant (and portable) solution for your problem would be to write a small tcl script which generates a list of defines/parameters, which then you add to your project or directly into your code (with an include statement for example). Then it's a matter of using ifdef type of directives to switch between different branches of code accordingly, and have a default branch as well for the portability's sake. You can even make the script to run automatically in Quartus at the beginning of a compilation flow, sort of the same approach Altera is using to generate specific code in their megafunctions.
