tfm
3 years agoALT_MULT_COMPLEX is not correct
I was looking for a complex multiplication, and found in the Quartus in IP Catalog, Library/Basic Functions/Arithmetric the ALT_MULT_COMPLEX.
I used it with a enable, let it produce a VHD f...
FvM
3 years agoQuartus version, target device, port widths and other non-default instantiation parameters?
- tfm3 years ago
Hi FvM,
Thanks for your reply..,
I already build my own complex multiplication, so i'm fine.
But to show the problem.., i attached the *.vhd file that was generated by the ALT_MULT_COMPLEX -IP.
at least one problem is: the IF (ena = '1') THEN do not have a closing END IF.
I used Quartus Prime Lite 22.1std. And used a Cyclone V
Kind Regards,
Theo Mulder
