HongLiang
3 years agoAgilex DP IP integration with F-tile PHY some signals mismatch
We try to build a DP Rx function in Agilex.
There are some DP RX interface need to connect to F-tile PHY IP
we can not find them in the F-tile IP interface.
We check the DP example...
ZH_Intel
3 years agoHi Liang Hong,
We have not heard feedback from you for quite some time.
As mention to you previously, since there is another forum case reported by you are pointing to same issue, I will proceed to transition this thread to community support to avoid miscommunication.
I will continue to support you via forum Case No.05751620
Thank you.
ZulsyafiqH_Intel
