nelky
2 years agoAgilex 7 HPS how to read from port B of 2-port RAM
Hi, I have used Quartus Prime Pro to design a component to write to port A of a 2-port RAM. For port B, it is supposed to be connected to Agilex HPS h2f_axi_master, which will perform a read. I sa...
sstrell
2 years agoYou're either inferring or adding a standard RAM IP through Quartus. If you use the "On-Chip Memory II (RAM or ROM) Intel FPGA IP", it has options for an Avalon or, better yet, AXI4, interface to connect to the h2f interface.
