Eric_100
2 years agoAgilex 7 devices design example programming failed.
Hi, OS: Win 11 Pro Quartus: Prime Pro 23.4.0 Build 79 I downloaded a sample code for Agilex 7 devices from https://www.intel.com.tw/content/www/tw/zh/design-example/787040/agilex-7-fpga-hello-worl...
- 2 years ago
Hi Eric,
I have tested the design example from my end and it is successful.
- Please used Quartus Pro version 24.1 as suggested for the design example.
- Upgrade you IP tool. I saw from your photo there is a pop up suggested to upgrade IP.
- Run the design example again.
Aiman
NurAiman_M_Intel
2 years agoHi,
-Can you share the screenshot of the error message?
-Has the design ever work before?
-What is the Quartus version that you used?
-Make sure to select the correct device (AGFB014R24B2E2V)
Aiman
Eric_100
2 years agoHi,
I have had a go at building the same system with Quartus Prime Lite and it can be successfully compiled.
Why does compilation always fail when using Quartus Prime Lite?
How can I fix this error message?
Eric
